Právě je pon 22.10.18 03:17
 Dex Manager
Poděkovali mu: 4153 x
Příspěvek Dex Manager
Dex Manager v1.1
Požadavky:
-WinRAR Or 7Zip To Drag "Classes.dex" From Apk Or Jar File
-JRE
-Microsoft .Net Framework v4.0 And Above
DEX MANAGER Has Been Built With The Idea Of Providing The Easy Work With Classes.Dex To End User,
It Is Fast, Stable, Smooth And NOOB FRIENDLY..!!
This is a GUI program Which Helps You To Decompile The Classes.dex And Compile It Back
With Just Clicking Options,No Need To Write Codes Or Commands To Decompile And Compile, It Handles Everything With Itself.
It Is Intended To Make Your Work Easy.It Is NOT Intended For Non-Legal Uses.It Could Be Used For GOOD Purposes.
Features:
- Decompile\Compile Classes.dex From APK Or JAR File.
- Beautiful AppleUI Theme
- Noob Friendly
- Much Faster And Clean,No Need To Put Commands Does Everything Automatically.
How Does It Work :-
- Drag And Drop "classes.dex" From Apk Or Jar To Dex Manager Root Directory By Opening The Apk Or Jar In WinRAR Or 7Zip.
- Option "Decompile" To Decompile The Dex File Which Gets Decompile In "Source" Folder.
- Now Modify The Code.
- Option "Compile" To Compile The Dex As "New_classes.dex" In Dex Manager Root Directory.
- Rename "New_classes.dex" To "classes.dex" And Drag And Drop To Apk Or Jar File.
- Option "Delete" Will Delete The "Source" Folder Dont Worry It Will Be Created By Itself When Performing Decompiling Next Time.
- Error Box Only Shows Error Of Decompiling And Compiling,If There Are No Error Shown You Will Get Desired Output.
Updated: Aug. 12, 2015
- Updated Baksmali/Smali To v2.0.6.
- Now All Compile,Decompile And Delete Error Are Redirected To Errorbox.
- Add Option To Copy Error From Error Box To Clipboard.
- Now Dex Manager Reads baksmali.jar and smali.jar From Binaries Folder So When New Update Of Baksmali/Smali Comes
You Can Copy Replace The Baksmali/Smali With Latest One.
- Change App Icon.
- Change App Skin Same As iTunes.
- Rework UI And Incresed UI Size.
- Code Refactor.
- Minor Optimization.
čtv 13.08.15 22:09
