Právě je pát 19.01.18 21:57
 StartIsBack
Moderátor
Poděkovali mu: 534 x
Member (1) High calibre silver (1)
Příspěvek StartIsBack
StartIsBack 2.1.1 Final
StartIsBack returns Windows 8 a real fully featured start menu and start button, behaving exactly like the ones in Windows 7.
Features:
Boot to desktop
Your session would start with the desktop. Always!
Unlike other solutions, StartIsBack goes directly to desktop every time without flashing Start Screen even for a millisecond.
Restore original fully-featured Windows 7 start menu - with new styles
StartIsBack restores original Windows 7 start menu with all its features: search, jump lists, drag&drop, pinned and recently used apps, fully customizable settings.
Start button and Start menu look and behave exactly as they used to in Windows 7.
StartIsBack includes fine-tuned visual styles and start button images that will fit your style and Windows 8 style.
Achieve the balance between Desktop and Modern UI
Lot of troubles bug long time users in Windows 8: overly active screen corners; Start screen jumping in your face; hotkeys not behaving the way they're expected to. StartIsBack allows you to fix many of those issues without breaking any usage scenarios, increasing your productivity with both Desktop and Modern interfaces.
Separate Desktop and Modern UI and make Start Screen clutter-free
StartIsBack is the only tool which is able to provide consistency in Windows 8 by separating desktop and modern programs.
Real work is done on desktop while new Start screen turns into launcher for modern apps only.
Windows 8 forces you to organize new Start screen which can quickly become a long list of mess with automatically pinned programs.
This is no longer the case with StartIsBack! If you turn Start screen into Apps screen, you won't have the pain to manage two Start places.
Totally native; fully localized
StartIsBack does not run any additional services or programs. It integrates into your computer smoothly.
It does not require any other tools or frameworks to install and can be installed without administrative privileges.
Start menu is fully localized into your language with same metrics and names Windows 7 had.
Rich customization and configuration
StartIsBack allows you to configure all aspects of appearance and behavior of Start menu.
This is done in most reliable way, within attractive and easy configuration UI.
You can even configure Start menu to work like Windows XP one!
More to come!
Jazyk: Čeština
Operační systémy: Windows 8 (32-64 bit)
Web autora:
Mé uploady !
Mnou netestováno !
#!/usr/bin/env php
Čtěte Linky v URL mohou vidět jen registrovaní uživatelé. Přihlaš se nebo registruj na fórum. a před vytvořením příspěvku použijte možnost Linky v URL mohou vidět jen registrovaní uživatelé. Přihlaš se nebo registruj na fórum.
sob 06.07.13 16:52
